Evolution
HoTTdog
I would like to talk about evolution. Like the dinosaur before it, the CRT is dead and is now replaced by flat-screen technology in the competing shapes of Plasma and LCD (yuck). Now it seems to me that the only reason these flat screens were developed was a result of an aesthetic imperative to mount them on the wall like a picture. And IMHO this is where they should be deployed. My PW8 is mounted thus and I can only gasp at its infinite beauty. It's even better when its switched on! I can't see the point in a plasma television sitting on a stand like a CRT.
However, I can undertsand why this has happened and the reason is that the associated media boxes (DVD, Amp, Sky, TV-Drive etc) have not evolved from their nautral habitat; namely the shelves of the stand holding the CRT.
Isn't somebody missing a trick here? Why can't I get my various media boxes in the same thickness as my plasma and then I wouldn't have to compromise the aesthetic by having to install a stand to hold them? I think only B&O have made any attempt to address this issue.
Does this irritate anybody else or am I just picky?
MaryJane
[First Post]
Yep, I agree with you.
I've just bought my first plasma and it's for the very reasons you stated that I bought a shelved glass plasma table rather than wallmount.
I'd love to have it hanging on the wall, but what's the point when you still need a table/stand for the VCR/DVD/Digi Box/PS2/Gamecube etc.!!!:)
sapper
MaryJane said:
[First Post]
Firstly welcome to the forums..
My plasma is wall mounted for a couple of reasons...
1. being wall mounted, it cannot be accidentally knocked over and damaged...
2. It i shigher then a normal TV; more of a cinematic expereince.
The boxes can be moved away from the plasma, and just a cable or two used to connect it.
When I have my room refurbsihed soon, the electronics will dissappear behind a wooden cupboard.
adrian
HoTTdog
sapper said:
...The boxes can be moved away from the plasma, and just a cable or two used to connect it.
That all dpends on the layout of your room/ability to cable away from the panel.
sapper said:
...When I have my room refurbsihed soon, the electronics will dissappear behind a wooden cupboard.
adrian
How does that work for the remote?
Cheers :)
sapper
Cheers :)
the plan is to have speaker grill material covering the door; this will aid ventilation of the units and allow IR to pass through.
For a couple of das I had the material over the units, and the Pronto seemed to work still.
For more information, click on my setup in my signature file.
Adrian
Similar threads
The Best Movies and TV Shows Coming To Amazon Prime Video in August 2020. Tom's Thumbs.
