Quantcast
Evoke 3 Upgrade Problem
gordonbuckley
After a power cut my 4 year old Evoke 3 has frozen and the screens indicates it is waiting for upgrade. I have visitied the Pure site and downloaded the upgrade file, but when I connect the radio to the computer Windows says it cannot locate the device driver for the radio. I have tried extracting the Upgrade program files to a folder and referring the Found New Hardware Wizard to that folder, but to no avail. Can anyone help me locate a device driver for the radio to enable me to get the software upgraded?
gordonbuckley
I have had a response from Pure who tell me that the driver for the Evoke 3 upgrade uses Windows 32 bit. Unfortunately I use 64 bit and so unless I reinstall Windows it looks like the end of the road. Anyone have any simpler ideas how to fix the problem?
