Evoke 3 snooze issues
Teflon
I recently purchased a Pure Evoke 3 DAB radio, and am experiencing some issues with the alarm functionality. Some 7 times out of 10, when the alarm goes off it goes into snooze mode after 2 or 3 seconds without anyone touching it. Has anyone else here experienced anything similar?
If I have a rogue unit then i will get it changed, however if this is a "known issue" with these sets then I will be after a refund sharpish.
A shame as I am happy with the set in all other respects.
All thoughts welcomed.
Teflon
A good thought (and a speedy reply!), however in this instance the set came with V1.1 already loaded so unfortunatley that's not the answer.
Thanks anyway.
Yes, I've found the same problem. When the alarm was supposed to go off it went straight into snooze. Retried it a couple of times and same thing each time. Then I just left it in snooze mode and the alarm (radio station playing) started after 2 snooze periods. I've not retried it since.
Teflon
Oh well - I've got a refund now, so no more problems ....... although I must admit that I am missing the set already. Perhaps I will try another one at some point - who knows?
Anyway folks, thanks for the responses - much appreciated.
J
jco
I would not give you too much hope.
I had a similar problem with my first Evoke-3 (the snooze handle did not work either). I returned it to the store and got a refund (they had no new units in stock).
After a week, I missed my radio and bought a new one on the Internet. Unfortunately, I have exactly the same problem as you mention.
I honestly believe all units are flawed (or I really have bad luck)
Jan
Similar threads
