Evoke 3 and 2gb SD card
Discussion in 'Music Streamers' started by jifster, Dec 25, 2006.
  1. jifster
    jifster
    Hi all,
    Anyone else tried a 2gb SD card in their Evoke 3.
    Mine records some times but other times states SD card not found, then when I set up to record a show, I go back to check it, ie in the morning and it states the card is full but this is impossible as it's empty when starting and a 2gb card should last ages (also the set up show is not on the card).
    I'm running another test now and it's been recording for a couple of hours but I need some realiability as it would be nice to set up recordings and know they are going to be there.
    I'm wondering if it's a compatability issue. The card is a Kingston 2gb 50x elite pro.
    Other than this I am very happy with the radio.
    Thanks for any input.
