Everybodys Golf - How do i advance onto other courses???
Discussion in 'PS Vita Forum' started by Billy C, Sep 3, 2005.
Tags:
  1. Billy C
    Billy C
    Aug 29, 2005
    198
    +9
    Been playing Everybodys golf and all i seem to be doing is playing the same course for absolutely ages ( South alps c.c).
    How do advance from this course, havent even played 18 holes as myet or unlocked any new characters yet! Help :lease:
    Will
  2. Sephiro
    Sephiro
    Jul 19, 2005
    433
    28
    +92
    In order to unlock new courses, characters and items you need to play match play (under the challenge mode menu). Each time you win a match you should receive a new item and certain matches (those with a star underneath them on the match select menu) will award you points to be promoted to the next tier (which unlocks new courses and somtimes caddies).
    It does take a fair amount of time to progress though as I've had the game for 3 months now and I've still to unlock the final course.
  3. jinky32
    jinky32
    Oct 17, 2004
    346
    +6
    always chose the courses that have gold stars available. once you get the stars you go up a level.
    you don't get to play 18 holes straight for quite a while
  4. chrislad
    chrislad
    May 6, 2005
    5,642
    83
    Rep. of Ireland
    +141
    If you go to single course, you can play 18 holes on any unlocked course.
  5. Billy C
    Billy C
    Aug 29, 2005
    198
    +9
    Thanks for the tips, will give it a crack tonight, see how i get on.
    One final question, When you chose challenge mode the 3 courses showing are those the one that havent been completed??
    cheers
    Will
  6. chrislad
    chrislad
    May 6, 2005
    5,642
    83
    Rep. of Ireland
    +141
    Challenge mode has 6 tiers. At a new game, you can only see 1. When you complete every tournament/match with a star on a tier, you will unlock the next course/tier. Sometimes, there will be no visible stars, so just complete the non-starred ones and starred ones should appear. When you go up a rank, a new course is available. It gets tricky from course 3 on.
  7. Sephiro
    Sephiro
    Jul 19, 2005
    433
    28
    +92
    If you have completed a tier you will still have 3 matches available on that Tier however they will not have any prizes or stars on the selection screen, instead they will be labeled with 'Open Tournament' or 'Open Match', so push the up direction to move to the next tier. Please note that you do not have to win all the items to move to the next tier just a certain number of the star matches.
    Contary to what Chris has said there are also more than 6 tiers, as I'm on 7 and I can see up to 9, plus it's possible that there are more than that as moving up a tier doesn't always give you access to a new course (sometimes it just gives you access to the long/reverse tee).
  8. chrislad
    chrislad
    May 6, 2005
    5,642
    83
    Rep. of Ireland
    +141
    I had the US version and that only had 6 so I assumed the UK only had 6.
  9. Sephiro
    Sephiro
    Jul 19, 2005
    433
    28
    +92
    I only have the US version myself and to my knowledge the only difference between the the US and UK version is a name change.
  10. chrislad
    chrislad
    May 6, 2005
    5,642
    83
    Rep. of Ireland
    +141
    And the music is different. Plus they call the Sand Trap a Bunker and the area around the green a Collar.
  11. Sephiro
    Sephiro
    Jul 19, 2005
    433
    28
    +92
    Ahh so that explains why sony decided to release the psp so late in europe they wanted to make sure that they had time for such important changes :D
    A bit off topic but has anyone tried ad-hoc multiplayer between "Hot Shots Golf" (US) and "Everybodys Golf" (UK)...... I'm guessing it wouldn't work but you never know.
  12. chrislad
    chrislad
    May 6, 2005
    5,642
    83
    Rep. of Ireland
    +141
    I've not tried it but I know that it hasn't worked with Wipeout, Tiger Woods and some oher game I can't recall, according to a friend of mine.
  13. jimborae
    jimborae
    Sep 16, 2004
    1,271
    2
    Berks
    +96
    Doesn't work between Jap Everybodys Golf & U.S. Hotshots Golf
