Eurosat @ 13 Degrees
Discussion in 'Satellite TV, Sky TV & FreeSat' started by MUD, Jan 21, 2002.
  1. MUD
    MUD
    HI
    IF I wanted to receive eurosat on 13D what sort of digital box should I get. also I used to get sat on analog. but when I changed over to sky digital i switched off my PACE analog I still have two dishes how many free to air would I receive I have been told you can get sat/football.
    THANKS MUD
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,216
    +3,071
    Hi MUD: Not quite sure what channel you mean with eurosat.
    I get all the channels from Hotbird at 13 degrees east using an 80cm DISH and a Humax 5300 Dvb box. It has a Viaccess decoder built in and a space for another CAM if required. I use ito to pick up French TV for Melanie....by product is you get Itallian, German, Swiss well....just about everything..
    Go get a What Satellite magazine and in the back you'll see listings of all the channels broadcast and what satellites they are on at what position in the sky. It also tells you if and how they are encrypted. With this info you should be able to work out what you need.
    Gordon
