Euro 1080 transmissions
Discussion in 'Televisions' started by aligebes, Jan 6, 2004.
  1. aligebes
    aligebes
    Jan 2, 2004
    229
    Edinburgh, Scotland
    +3
    To those people who are lucky enough to view this channel, I hope you can help me please:-
    1. What equipment do you use to view it?
    2. What has it been transmitting, I know what it says, but I would like to hear from real people
    3. If you are using a PC to view this, what sat card are you using and what is the spec of your machine?
    I need to justify what the channel will give me before I'm allowed to get an engineer to realign and fit a new LNB to the dish. The dish itself is an 80cm channel master black dish.
    I also would like recommendations on a good quality LNB please.
    My plan is to have the whole lot routed through my PC
  2. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,869
    68
    +47
    Have a read though all the threads, you'll find all the answers and more. In short though it's worth getting a Skystar 2 card for £53 incl postage from a German site at
    http://www.dvbshop.tv/
    You will receive the HDTV broadcasts and of course all the other many 100's of FTA tv and radio channels around in Astra Hotbird, W2 etc etc
    OH a dish helps of course! 80cm minimum size
  3. aligebes
    aligebes
    Jan 2, 2004
    229
    Edinburgh, Scotland
    +3
    Thanks, I just needed someone to summarize it all. I have been reading the threads on satellite through your PC.
    I have an 80cm dish, and it will be getting fitted with a new high gain LNB. I will visit the link you have supplied.
    Thanks again
  4. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,869
    68
    +47
    The cost of a new LNB is so cheap now. They were 10 times what they are now just a few years ago...
