Ethernet Switch into another switch?
Discussion in 'Networking & NAS' started by johnmerrick, Jan 9, 2012.
  1. johnmerrick
    johnmerrick
    Jan 31, 2005
    736
    Poole
    +14
    I currently have a server and router in the loft.
    Each room in my house has an ethernet connection in the wall going up to the router via two gigabit switches.
    In one of the rooms i am going to need more ethernet connections than the one going into the wall ( for TV, HTPC, PS3 etc).
    can i just add another switch in that room (or old router with dhcp disabled) to expand my ethernet connections? ie will the new switch just connect to the router via the other switches without a problem?
    thanks
  2. ralphmalph
    ralphmalph
    Jun 4, 2006
    1,193
    63
    +133
    Yes
  3. BT Bob
    BT Bob
    Nov 22, 2006
    2,309
    116
    Cardiff
    +1,062
    If you're connecting the new switch to an existing one, you might need a cross-over cable - depends if either switch is intelligent enough to auto-detect the cable type.
  4. ukprometheus
    ukprometheus
    Nov 4, 2006
    922
    28
    +83
    you should be fine to cascade the switches, i would be surprised if you need a crossover cable :smashin:
  5. MikeK
    MikeK
    Oct 9, 2004
    2,231
    83
    +316
    You don't for gigabit - it's auto-detect on all ports!
    10/100Mbps ethernet switches may need one, but often have either a designated port with auto-detect, or else a port with a push switch to configure the connection type.
  6. beerhunter
    beerhunter
    Nov 9, 2005
    6,335
    Hampshire
    +740
    I haven't come across a switch that doesn't auto detect for donkeys years.
  7. Kristian
    Kristian
    Oct 1, 2002
    2,234
    83
    Sunny Scunny
    +439
    Cisco 2950 series ;)
  8. johnmerrick
    johnmerrick
    Jan 31, 2005
    736
    Poole
    +14
    Thanks everyone, just bought a TP-link one with good reviews (my others are Zyxel and I never have to go near them)
    on another note, does anyone know how to fix an ethernet port on a laptop? The port works if you push down slightly on the cable connection and it stays on, but is there soldering involved if i was to take the laptop apart?
    Or should i should I just 'tape' it into position?
  9. BT Bob
    BT Bob
    Nov 22, 2006
    2,309
    116
    Cardiff
    +1,062
    Ah, but I'm an old bugger!!! :D
    And the OP didn't mention what type of devices he was connecting up.
  10. BT Bob
    BT Bob
    Nov 22, 2006
    2,309
    116
    Cardiff
    +1,062
    Ha ha - exactly right. I've still got a couple of 3524s & and 1912 in my workshop. Hardly bleeding-edge, but great for testing.
