For some reason BT/TalkTalk/Sky will only put the router in the hallway at the phoneline connection in my new flat.
For other reasons I have already ruled out wifi and Powerlines.
So Im left with using ethernet cables to get to my PC/PS4.
Its just a bedsit and the distance on foot is about 4 meters. But if I want to tidy cables away, then it comes to 15m! going up and around two door frames and also round the inside of a door frame (cant drill holes in wall)
The other option is to go along the floor, maybe putting cable under and along a special carpet divider and then directly through a divider on the second door, (ie like "+" with the horizontal line being the divider and the vertical line being the cable) then just tacking on to skirting boards in main room?
Im conscious of it being a high rise flat and would appreciate advice on fire safety firstly, then any tips about either method, if possible?
Not sure if its best to get flat ethernet and Im reading lots of conflicting advice about carpet damage or cable just wearing out. If it lasts a year or so then its just something I willing to live with, but some people have talked about carpets being damaged or cables being a fire risk.
Amazon list their flat own ethernet as "ideal for under carpets" but Ive read I should be looking for mention of "POE" on cables for fire safety, which Amazon dont mention.
Sorry for long post, thanks for any help forthcoming
