ET1 computer connecton
Discussion in 'Projectors, Screens & Video Processors' started by JohnRaymond, May 7, 2005.
  1. JohnRaymond
    JohnRaymond
    Jan 5, 2005
    54
    11
    Appley Bridge, Lancs
    +4
    Hello,
    Anyone had problems connecting their ET1 to a laptop via the 15 pin d-sub conection.
    My PC will not recognise the projector at all.
    Ihave tried installing latest graphics drivers but nothing....all i get is no signal.
    The pc and cable are fine as I can connect to an other projector no probs.
    Any ideas people? I am beginning to suspect a dead computer port on the projector .
    cheers
    john
  2. willsy2
    willsy2
    Apr 22, 2005
    634
    28
    Newcastle
    +31
    I take it you've enabled the external VGA port - my Hewlett Packard laptop uses the Fn F4 key combination.
  3. JohnRaymond
    JohnRaymond
    Jan 5, 2005
    54
    11
    +4
    Will keysy2
    Yes its a fujitsu siemens amilo and the same key combo for enabling but no joy
    john
  4. Maff et1
    Maff et1
    It's possible the PJ can't sync to the resolution/refresh rate from the Laptop (will normally match that of the laptop's screen).
    I've had my ET1 running at 1280x1024 and 1280x720 (both 60hz) and it scalled them OK.
    There is a list of resolutions/refresh rates in the manual, ensure you're sending one of these. Check the PJ on another PC is the next step - otherwise it does sound like a defective PJ
