eSecure External USB 2.0 Slim CD R/RW Drive Burner Writer - Anyone bought one?
SOUNDSTYLE
I'm wondering if anyone has bought the above cd burning drive and how have they found it.
What I really want to know, is if you can burn a audio cd with nought '0' second gaps between each track.
I'm using cdburnerxp but the burning drive I'm using at the moment won't allow me to do this.
SOUNDSTYLE
If you have gaps, then you're not burning correctly, the drive has nothing to do with it. Make a ISO from original to image to HD. Or if you're building a compilation select no pre-gap.
How to Burn a CD With No Gaps | eHow.com
I've done all that, but it looks like my drive does not allow '0' second gaps.
I need a new drive.
