eSata SSD drive - external boot?
Discussion in 'Desktop & Laptop Computers Forum' started by shabba2, Sep 6, 2012.
  1. shabba2
    shabba2
    May 3, 2006
    119
    +3
    Hello all,
    I wonder if this would work....
    If I bought a 2.5" caddy with an eSata port and added an SSD drive, would I be able to install Windows 7 directly to it and boot off of it?
    I tried this with USB before and it was a total nightmare, some people said it was possible but honestly it was not easy to get the OS on - even when I finally did it kept blue screening.
    I'm thinking the eSata port might not have the limits of USB in that sense, windows will see it and allow the install maybe as it doesnt know the difference between that and an internal drive?
  2. brookheather
    brookheather
    Nov 20, 2005
    5,293
    London
    +930
    As far as Windows 7 is concerned the eSATA drive is no different to an internal SATA drive so yes you can boot from it.
