mossmanfly
Established Member
Trying to capture my first tape but keep getting sound errors in Ulead VideoStudio 7 and video errors in Movie Maker 2.
I first tried VideoStudio 7 and the audio would keep cutting out for a split second at the same points. I then have done Movie Maker 2 and at points the sound cuts out and even at one point it seemed to jolt along and missed out footage and wasnt really smooth.
Now the system is an XP2800 with 1Gb, and 2 x 120Gb ATA133 7200rpm 8mb drives. Capturing onto a drive with over 40Gb and can hold 4 hours of footage. I did put the Virtual Memory(Paging file) to default with Win XP Pro. Changed it now to what I have for my C drive and that is 1536 minimum and then 3072 maximum. Havent tried capturing on this setting yet. Any recommendations on Virtual Memory size?
The tape is fine as I have played it back on the camcorder and watched it on TV. VideoStudio 7 captured the footage alot better than what Movie Maker 2 did, so I am sure that its something software related or maybe hardware.
I have onboard Firewire so it could be that, but if it was then I would have thought it would mess up the captured footage the same time for both programs. Would it be a virtual memory problem? As it seems to cut in on VideoStudio 7 at the same time and then be ok afterwards.
I am not using the computer while its capturing. The drive that I capture to is my E drive which is on the same hard disk as the C drive as I basically split each 120Gb in half. So would this affect anything considering the C drive has all the programs etc? Would it be better to use the other drive which is basically D and F which are mostly free?
Any advice would be helpful as i've capture the footage 4 or 5 times so far.
