Error when playing any DVD's
Discussion in 'Blu-ray & DVD Players & Recorders' started by Himji, Mar 7, 2005.
  1. Himji
    Himji
    Jan 6, 2005
    63
    My players started to have problems playing any DVD.
    Basically what happens is he DVD will play fine for an unspecified amount fo time, say between 10-45 mis. Then it will either freeze or reboot to the main screen sometimes displaying an error. After this, if I try to play the DVD again, it will freeze very early on and will just display error on the screen. Eventually it will completely lock up. Only a hard reset will fix this.
    FWIW it's a Yamaha S520 player and it's had very light use (maybe 10 DVD's a month tops, I've had it about 2 1/2 years (I think). I've tried a lens cleaner but no joy :(
    Anybody have any suggestions? At first I just assumed lens but could it be some sort of overheating issue???
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    If it were a PC displaying this sort of behaviour I certainly would be inclined to think of over-heating as a possible cause.
  3. nwgarratt
    nwgarratt
    May 5, 2002
    27,830
    +3,195
    I am also thinking overheating. Is it in a stack with limited ventilation?
    Otherwise, I might be looking a problem with the drive inside. I had similar problems with a player and it was the drive unit at fault.
    Can you try the DVD's on another player to make sure it isn't the discs.
  4. Himji
    Himji
    Jan 6, 2005
    63
    Yeah I got the DVD's plying outta my xbox atm (good thing I don't play it anymore) but the things bloody noisy!
    It's on a shelf but sandwiched between my amp and my sattelite box... I might try it out in the open see if that helps it.....
  5. ahin4114
    ahin4114
    Nov 1, 2004
    1,066
    Reading
    +48
    Sounds like a plan, if it's anything like my amp, then it's gonna get pretty warm up there.
  6. Himji
    Himji
    Jan 6, 2005
    63
    Funny thing, I didn't even think of the overheating thing until I'd typed out the post....
  7. Himji
    Himji
    Jan 6, 2005
    63
    Hmm, tried that but no joy :(
    any thoughts before I trash the machine??
