CPORetired
The Receiver is brand new. I powered it up and it first said See TV for set up. Then it started giving me this error code.
I just wanted to thank you for this tip. I had been using an old A/V receiver while my Onkyo NR-676E sat on a shelf because of the NG error. I had just contacted a repair service and of course, they asked what the error message was. That's when I checked this site. I ran through your procedure and all the error messages cleared, but I had video and no audio. I ran a firmware update and everything is now great. Many thanks for the tip.I developed this problem while updating firmware. Found a solution on another site, which I would like to share for good order -
Press "Enter" and Power Button together. It will clear the NG error. The screen will display Amp-Dialogue/chk speaker wire error. Press CBL/SAT and the power button together. This error will be cleared too and you will be prompted to do the initial set up on the AVR.
I had to register on here just to tell you that you are an absolute bloody genius! 2 months I've been trying to get the thing out of the error cycle. And all fixed in under a minute, thanks to you.I developed this problem while updating firmware. Found a solution on another site, which I would like to share for good order -
Amazing! My unit broke down 4 years ago and have not been able to use it because of this error. This tip cleared the error within 10 seconds!! Thank you very much!I just wanted to thank you for this tip. I had been using an old A/V receiver while my Onkyo NR-676E sat on a shelf because of the NG error. I had just contacted a repair service and of course, they asked what the error message was. That's when I checked this site. I ran through your procedure and all the error messages cleared, but I had video and no audio. I ran a firmware update and everything is now great. Many thanks for the tip.
I have a question. Can firmware update be run while unit is in diagnostic mode?I had to register on here just to tell you that you are an absolute bloody genius! 2 months I've been trying to get the thing out of the error cycle. And all fixed in under a minute, thanks to you.
I will be raising a glass/saying a prayer for you tonight, whatever your preference may be.
Thank you so much.![]()
We have had to do this about four times on our new warranty-replacement Onkyo TXNR-696 receiver since December; it always seems like the indicated fault on the display is completely unrelated to what's going on with the receiver, i.e., It's never been the speakers causing the issue even though that is what the receiver likes display when it fails.I developed this problem while updating firmware. Found a solution on another site, which I would like to share for good order -
