Error attempting to burn DVD
Christoc
Hoping someone can help...
I have created a movie in Movie Maker and am attempting to burn it to disc using free software "DVD Flick" but an error has occurred and im unable to understand the error log to know what the problem has been.
NB: I have also attempted to burn using an external DVD burner but the same error occurs.
I succesfully burnt a DVD a few months back using "DVD Flick".
Im pasting the full error below, hoping someone with more knowlege can interpret for me! :)
Many thanks!
An error occured during the encoding process.
-1 from muxStreamsMPLEX: File was not multiplexed.
Code:
DVD Flick error log
Version 1.3.0.7 build 738
Windows 6.2 build 9200
*** Project info
EncodeProf 2
Threads 4
OverScan 0, 3
TargetRate 0
TargetFormat 0
TargetSize 4
CreateISO 0
CustRate 0
EnableBurn 0
EraseRW 1
HalfRes 0
LoopPlayb 1
AutoPlayMenu 1
MenuTemplt None
VolumeMod 100
WhenPlayed 0
*** Warnings given
*** Titles
0 - WWI Drunkenlords 2015 0.2
    ChaptCount -1
    ChaptInt -1
    ChaptSource 1
    TargetAR 0
    ThumbIndex 237
*** Project sources
    C:\Users\Chris\Documents\Pictures\Events\DL 2015 06 03 DL June WWI\WWI Drunkenlords 2015 0.2.mp4
    Stream 0 (2)
        Dur 2373.37
        StartT 0
        Compr h264
        BitR 0
        640x480 29.97 FPS
        PAR 1
        SAR 1.333333
    Stream 1 (1)
        Dur 2373.37
        StartT 0
        Compr aac
        BitR 0
        Chnnls 2
        SRate 48000
        Delay -160
*** dvdflick.log
13:43:26: DVD Flick 1.3.0.7 build 738
13:43:26: Calculating stream sizes...
13:43:26:     Disc space used : 2662922 KB
13:43:26:     Average bitrate : 9000 Kbit/s
13:43:26:     Total duration  : 39:33 minutes
13:43:26: 1 title(s).
13:43:26: Using Normal encoding profile.
13:43:26: PAL target format.
13:43:26: CPU: Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz
13:43:26: Threadcount: 4
13:43:26: Encoding video...
13:43:26:     Title 0, source 0
13:43:26:         Source         : C:\Users\Chris\Documents\Pictures\Events\DL 2015 06 03 DL June WWI\WWI Drunkenlords 2015 0.2.mp4
13:43:26:         Properties     : 640x480, Normal (4:3), 29.97 FPS, h264, 2373.37 seconds
13:43:26:         Target BitRate : 9000 Kbit\s
13:43:26:         Re-encoding
13:43:26:          -i "C:\Users\Chris\Documents\Pictures\Events\DL 2015 06 03 DL June WWI\WWI Drunkenlords 2015 0.2.mp4" -vcodec mpeg2video -s 720x576 -r 25 -g 12 -bufsize 1835008 -packetsize 2048 -muxrate 10080000 -aspect 4:3 -minrate 8950k -maxrate 8950k -b 8950k -preme 1 -precmp 2 -subcmp 8 -mbcmp 8 -cmp 1 -sws_flags lanczos+accurate_rnd -mbd 2 -sc_threshold -3000 -dc 8 -an -threads 4 -fflags +genpts -f mpeg2video -shortest -map 0:0 "C:\Users\Chris\Documents\Pictures\Events\DL 2015 06 03 DL June WWI\DVDBurn\0.0.m2v"
13:57:32: Combining video sources...
13:57:32:         Concatenating video...
13:57:32: Encoding audio...
13:57:32:     Title 0, track 0, source 0 of 0
13:57:32:         Source     : C:\Users\Chris\Documents\Pictures\Events\DL 2015 06 03 DL June WWI\WWI Drunkenlords 2015 0.2.mp4
13:57:32:         Properties : 2 channels, 48000 Hz, aac, 2373.37 seconds
13:57:32:         Recompressing to 192 Kbit\s with 2 channel(s)
13:57:32:          -i "C:\Users\Chris\Documents\Pictures\Events\DL 2015 06 03 DL June WWI\WWI Drunkenlords 2015 0.2.mp4" -i "C:\Users\Chris\Documents\Pictures\Events\DL 2015 06 03 DL June WWI\DVDBurn\0.0.m2v" -map 0:1:1:0 -acodec ac3 -ab 192k -ac 2 -ar 48000 -threads 4 -async 0 -shortest "C:\Users\Chris\Documents\Pictures\Events\DL 2015 06 03 DL June WWI\DVDBurn\0.0.0.ac3"
13:58:11:         Fixing delay of -160 ms
13:58:11:         -start -160 "C:\Users\Chris\Documents\Pictures\Events\DL 2015 06 03 DL June WWI\DVDBurn\0.0.0.ac3"
13:58:12: Combining audio sources...
13:58:12:         Concatenating audio...
13:58:12:             Title 0, track 0
13:58:12: Combining sources...
13:58:12:         Multiplexing audio and video
13:58:12:             Title 0
13:58:12:             -f 8 --vbr -o "C:\Users\Chris\Documents\Pictures\Events\DL 2015 06 03 DL June WWI\DVDBurn\title0.mpg" "C:\Users\Chris\Documents\Pictures\Events\DL 2015 06 03 DL June WWI\DVDBurn\0.0.m2v"  "C:\Users\Chris\Documents\Pictures\Events\DL 2015 06 03 DL June WWI\DVDBurn\0.0.ac3"
13:58:14: -1 from muxStreamsMPLEX: File was not multiplexed.
*** 0.0.0_log.txt
ate=192.000000
Sampling Frec=48000
TotalFrames=74168
Bytesperframe= 768.0000
Filesize=56961024
FrameDuration= 32.0000
Framespersecond= 31.2500
Duration=00:39:33.376
Channels mode=2/0: L+R
LFE=LFE: Not present
[Target info]
StartFrame=5
EndFrame=74167
NotFixedDelay=  0.0000
Duration=00:39:33.216
====== PROCESSING LOG ======================
Seeking....
Done.
Processing....
Number of written frames = 74163
Number of Errors= 0
*** ffmpeg_audio_title0_track0_source0.txt
1361kB time=2191.39 bitrate= 192.0kbits/s
size=   52113kB time=2223.49 bitrate= 192.0kbits/s
size=   52820kB time=2253.63 bitrate= 192.0kbits/s
size=   53546kB time=2284.61 bitrate= 192.0kbits/s
size=   54244kB time=2314.40 bitrate= 192.0kbits/s
size=   55083kB time=2350.21 bitrate= 192.0kbits/s
size=   55626kB time=2373.38 bitrate= 192.0kbits/s
video:0kB audio:55626kB global headers:0kB muxing overhead 0.000000%
*** ffmpeg_video_title0_source0.txt
2586442kB time=2367.40 bitrate=8950.0kbits/s
frame=59227 fps= 70 q=2.0 size= 2588233kB time=2369.04 bitrate=8950.0kbits/s
frame=59266 fps= 70 q=2.0 size= 2589938kB time=2370.60 bitrate=8950.0kbits/s
frame=59308 fps= 70 q=2.0 size= 2591773kB time=2372.28 bitrate=8950.0kbits/s
frame=59333 fps= 70 q=2.0 Lsize= 2592866kB time=2373.28 bitrate=8950.0kbits/s
video:2592866kB audio:0kB global headers:0kB muxing overhead 0.000000%
*** mplex_title0.txt
header info: AC3 Audio stream 00 (C:\Users\Chris\Documents\Pictures\Events\DL 2015 06 03 DL June WWI\DVDBurn\0.0.ac3)
   INFO: [] AC3 frame size = 768
   INFO: [] AC3 AUDIO STREAM:
   INFO: [] Bit rate       :    24576 bytes/sec (192 kbit/sec)
   INFO: [] Frequency      :     48000 Hz
   INFO: [] SYSTEMS/PROGRAM stream:
**ERROR: [] Could not open for writing: C:\Users\Chris\Documents\Pictures\Events\DL 2015 06 03 DL June WWI\DVDBurn\title0.mpg
*** Project destination folder
    0.0.0_log.txt    483
    0.0.ac3    56957184
    0.0.m2v    2655094406
    dvdflick.log    3051
    errorlog.txt    8326
    ffmpeg_audio_title0_track0_source0.txt    6494
    ffmpeg_video_title0_source0.txt    134416
    mplex_title0.txt    1809
*** Drives
    C - Windows - 2
    FS NTFS
    AvailSpace 509339
    FreeSpace 509339
    TotalSize 913490
    D - LENOVO - 2
    FS NTFS
    AvailSpace 24292
    FreeSpace 24292
    TotalSize 25600
E - not ready
next010
Looks like its failing on merging the converted output into an mpg, why is unclear to me.
You could use ConvertXtoDVD the trial version lasts for 7 days, if its just a one off job.
LV426
Administrator
Staff member
Tends to suggest that
a) it is attempting to write this file
b) and it can't.
Why?
Possibly for example
  • file already exists and is locked (eg is already open in another app, or was and was nver properly closed)
  • insufficient space
  • file exists but is in a folder with restricted access
  • etc.
I don't know this app - but can you set a different output path and/or filename?
Christoc
Thanks both.
LV426 - Will try change if title if i can for starters.
next010- i often want to create dvds so really looking for a long term solution.
Christoc
UPDATE: Nigel - changing the name fixed it! Thanks!
However now i have another problem... when i play the disc, the photos i took in portrait view and subsequently changed to landscape view before creating the windows movie maker (WMM) file, have remained in portrait on the DVD! ..
I have checked and the WMM video is OK... they are all the correct way up... but when the video was created the video has turned them back round...
any advice on that appreciated!
LV426
Administrator
Staff member
That will be something that is app specific (i.e. Movie Maker) and it's not something I use. It may be possible to do what you want with MM, or perhaps for this particular purpose, you need to consider a different editor to create a slideshow video sequence.
Christoc
Thanks again. I'll look into it and if need be create a new thread!
LG G1 OLED Evo TV and SVS SB-1000 Pro subwoofer reviews, Samsung OLED rumours and more...
