Erisson K700i - Software problems?
Discussion in 'Mobile Phones Forum' started by AJL, Apr 11, 2005.
  1. AJL
    AJL
    My K700i, which I've had about 4 months has recently started showing a strange problem. Sometimes, when someone calls, the phone seems to pluck the wrong name out of the phonebook to show as the person who is calling you. For instance, whenever my girlfriend phones it displays the name of a double-glazing firm. If you check that entry in the calls log it shows her number correctly though. Also, when she sends a text it displays her number but no name at all.
    I have had problems like this when phoning out as well, I rang an estate agent from my phonebook this morning and when I'd finished the call it said I had called my decorator, although again the number was actualy the one I had called.
    Anyone know what this might be?
    J.
  2. EnigmaCode
    EnigmaCode
    Dec 16, 2004
    265
    +21
    update your firmware. its a common problem on the k700i.
  3. Barrovian
    Barrovian
    Oct 29, 2002
    1,039
    Second star to the right and straight on 'till mor
    +111
    Sorry to stick my nose in, but as I'm considering buying this phone, how do you 'update your firmware'? Does this involve sending the phone away etc?
    Apologies if it's a silly question.
    John
  4. AJL
    AJL
    Cheers.
    J.
