Equipment Placement
Discussion in 'AV Receivers & Amplifiers' started by JZEE, Feb 12, 2005.
  1. JZEE
    JZEE
    Jan 8, 2005
    I have a Yamaha RX-V450 AV receiver and a Samsung HD-935 DVD player.
    I plan to place the AV receiver on the top of the DVD player due to space constraints. Does anyone know whether this will negatively affect the DVD player due to the receiver's considerable weight?
    Thanks.
  2. samjet
    samjet
    Jan 1, 2005
    1,419
    38
    notts
    +5
    would not think thats a good idea :nono: as the amp weighs 11kg
    i would look at alternatives
  3. JZEE
    JZEE
    Jan 8, 2005
    Well the other option would be to put the receiver at the bottom but that would close its air vents on its top - looks like I'm stuck..... :(
  4. samjet
    samjet
    Jan 1, 2005
    1,419
    38
    notts
    +5
    just off the top of my head is there not some way you could sit the dvd on say some large wooden spikes to give the amp say 25mm top clearance for ventilation?
  5. JZEE
    JZEE
    Jan 8, 2005
    Thanks :thumbsup: - could be an idea - I'll have a look and see what I can find.
