The creator of the Twinthesiser the web-based software which turns posts made on Twitter into real sounds will present his latest project as part of the 2011 Festival of Design and Innovation at Bournemouth University. Sam Harman, who is just completing his BSc (Hons) in Music and Audio Technology, will demonstrate his new iPhone application as part of the Festival which opens for a private view on Thursday, 23 June before opening to the general public on Friday, 24 June.
Sams iPhone Impulse Response Application is designed to capture the acoustical characteristics of a room, (otherwise known as an impulse response) which can then be duplicated through a computer. Its really designed for musicians, audio technicians or acousticians but the application makes it easy for anyone to use, Sam enthuses. Previously its required a lot of microphones, cables, laptops, etc but now you can just do it all on your iPhone and then plug-in to your computer and use the data collected by the application to make any audio on your computer sound like it was being performed or recorded within the room or environment that youve captured.
It had to happen.
It had to happen.
