Epson TW10H "better" remote control?
Discussion in 'Projectors, Screens & Video Processors' started by RichKS, May 6, 2005.
  1. RichKS
    RichKS
    Apr 25, 2005
    506
    Southampton
    +38
    Everyone who's ever seen one of these will know that the remote is small, fragile looking, easy to use and feels horrible. Can someone recommend a multi-function/programable/learning remote that they know works with Epson PJs?
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,132
    +563
    I'm not an expert but don't most/all of these multi device learning remotes work by pointing whatever existing remote you like at the multi one and it "learns" the signals. Hence you should be able to use any?
    ...PJ
  3. RichKS
    RichKS
    Apr 25, 2005
    506
    Southampton
    +38
    From an extensive trek about town, apparently no. Most of them appear to "know" what input devices want. ie, they are pre programmed with a set of controls for most high street kit.
  4. willsy2
    willsy2
    Apr 22, 2005
    634
    28
    Newcastle
    +31
    The Cambridge Audio M1+ seems to learn from your existing remote.
    Review here
    Available from Richer Sounds for £49.95.
    I'll probably get one to replace my Epson PJ remote. I'ts bound to get lost otherwise.
  5. noel-pilot
    noel-pilot
    Dec 20, 2004
    mine never lives in the funky little slot (although i think its a great idea!) the alst thing i want to do is go scrabbling round the back of the projector for the remote!
    I definitely need a learning remote but Im gonna want to do macros and Im not sure how it will handle the lack of dedicated input buttons for the PJ. having the two inputs to each button is a real pain!!
    anyone know any way round this?
  6. noel-pilot
    noel-pilot
    Dec 20, 2004
    hmmm just done a tutorial setup on logitechs site and maybe that wont be a problem, it seems to know the dual button bit and appears to be able to handle it fine.
  7. RichKS
    RichKS
    Apr 25, 2005
    506
    Southampton
    +38
    I have a Cambridge Audio M1 which I bought about 6 years ago. I don't use it because of the pathetic battery life and the fact it uses AAAs. And it's too big and heavy for my hands, I found it rather uncomfortable. Plus it never seemed to work with my Wharfdale DVD player, which kinda defeated the point of having it.
    I've just bought the Gemini "learning remote" for 15 quid from Asda. I'll see how I get on with that.
