Epson TW10 Projector power cable
Discussion in 'Cables & Switches' started by tonydsam, Jul 28, 2005.
  1. tonydsam
    tonydsam
    I have finally decided to buy my projector next week, the Epson Tw10. And I have found a reasonable priced 10m component cable but it has just occured to me I will need a longer power lead as I doubt the on supplied will be the 6-7m that I need. Does anybody know what sort of power cable comes with the projector and where I could get a longer one?
  2. ArsoN
    ArsoN
    It comes with a standard "figure of 8" connector (what you get on small stereos and "ghetto blasters" and the such). It's about 1cm long, and about 0.5cm wide. I'll grab a pic if you're still unsure.
    [Edit] Found a link through a quickle google:
    http://www.dunamys.co.nz/images/cpowern8.jpg
  3. tonydsam
    tonydsam
    Thanks a lot for the info, that sounds as though I should be able to find one easily then. Any idea of prices?
