block
Established Member
Hi another one who picked the tw5300 at a great price as a step into projectors.
Not sure if it's a problem but I put the projector on a table facing the wall just to get used to it, turned it on and the image is slanting from left to right. The table is flat and it's pointing straight on towards the wall.
I can use the keystone to adjust it but was wondering is the projector faulty or that is the norm and one just use the keystone adjustment?
