Epson throw distance???
Discussion in 'Projectors, Screens & Video Processors' started by callipo, Aug 8, 2005.
  1. callipo
    callipo
    Mar 9, 2005
    45
    Will be getting the TW10h Pretty soon :)
    Just a few questions :lease:
    The room i have is 12ft X 8ft and so was wondering if i could mount the PJ on the back wall.Having looked at the image calculator this would give me a diagonal image of 84".
    Would the SDE be bad at this distance?
    If so is it possible with this PJ to shrink the image down to the required size?
  2. callipo
    callipo
    Mar 9, 2005
    45
    Anybody???
  3. lee789
    lee789
    Nov 21, 2003
    441
    +3
    I have mine at a similar distance and you can see screen door if you look hard (and some movies are better/worse than others) but I don't see it as a massive problem.
    From looking at http://www.projectorcentral.com/Epson-PowerLite_Home_10+-projection-calculator-pro.htm
    I get 84" diagonal from 11' away not 12', so it may be bigger.
    This is on the max zoom so you won't be able to get a smaller image. This is the onw downside of this projector for me that if you have a long throw there isn't sufficient negative zoom (if thats a word).
  4. callipo
    callipo
    Mar 9, 2005
    45
    Thanx
    looks like i may need to ceiling mount a little closer to the screen.
    Her in doors will be pleased :nono:
  5. lee789
    lee789
    Nov 21, 2003
    441
    +3
