epson placement
Discussion in 'Projectors, Screens & Video Processors' started by progomez, Mar 20, 2005.
  1. progomez
    progomez
    Feb 24, 2005
    30
    Hello,
    I have a hi fi cabinet which has a front opening. If I put a projector inside should I take the back off the cabinet for air etc? Which direction does the projector draw in the air? Does anyone know of any problems with placing a projector in a cabinet?
  2. Kramer
    Kramer
    Yes, overheating :D .
    Seriously, ventilation is crucial for long term reliability. LCDs are more prone to heat damage - discolouration of panels etc.
    As long as you've given adequate clearance at the exhaust - no build up of hot expelled air & a good supply, you should be OK.
    This is very important though :lesson:
    :smoke:
  3. progomez
    progomez
    Feb 24, 2005
    30
    am i right in thinking the exhaust is at the front of a tw10h?
    how do you know when the lcd gets discoloured?
    will having the back of the cabinet open give enough air intake?
    thanks
