Epson photo 915 (stand alone use) - Compatible Cartridges
Discussion in 'Photography Forums' started by fmason, Nov 2, 2003.
  1. fmason
    fmason
    Anyone having difficulty using the 915 (stand alone - no computer) with non-epson cartridges.
    I bought this printer for my Mum to use with her Canon Ixus 400 / Compact flash card - She doesnt have a PC so the 915 is a great solution. Used up the supplied Epson colour cartridge pretty quickly (as you do during week 1 of a new printer!) and tried to install a compatible today (I use the same (compatible) brand with my photo 830/Win XP with no problems - get the usual "This is a non-Epson cartridge do you want to continue" message). The printer wouldnt carry on. i.e red cartridge empty/paper problem light continuing on red - printer display continuing to flash cartridge empty error code - despite pressing the charge cartridge button on the printer.
    I do hope this isnt an Epson hard-coded "feature" in the printer firmware to stop stand-alone users using non-Epson cartridges!!
    Any help would be much appreciated
  2. stuthemong
    stuthemong
    Dec 31, 2002
    432
    +6
    i know nothing about which carts can be used, but a lot of manufacturers put much smaller print carts in as a 1st set.
    Also, you lose a lot initially priming the head.
    a replacement epson cart will last longer than the first. Maybe worth a go?
    Stu
  3. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Post something here at 18:00 and then I will see it and paste in the URL for £4 cartridges
