alleycat41
Will be selling my epson eh tw7000 over the next few days will put ad on tomorrow with pics
HiDear 494930
It is on all possible refresh rates. I have tested all possible scenarios and in every of it the problem is the same.
Sincerely
I maybe a little late on this, but I am thinking of getting the Epson 7100 and was reading this thread. I found this review which mentions the issue you mention. Roughly translated it says don’t only run the Beamer on Eco for the first 100 hours. Epson EH-TW7000 • HD-Beamers.nl • Review video • Veelbelovend nieuw model: '4K', HDR, 3LCD •
Opmerkingen
I have one question about the 7100 can it display 1440p from a PC?
- Ten opzichte van de TW6700 is de trade-off verminderd contrast. Dit maakt vooral uit bij de perfecte thuisbioscoop setting zonder ander licht. Wanneer je de TW7000 in de woonkamer gebruikt maakt dat minder uit.
- De TW7100 lijkt erg op dit model maar is voorzien van interne stereo speakers, een trigger port en heeft op papier een wat beter contrast.
- Tijdens de eerste 100 uur kan veelvuldig gebruik van de eco modus het beeld doen laten trillen/flikkeren. Gebruik dus niet alleen maar de eco modus in het begin.
Regards
Atari
You really does not want to do that. It is 1080p projector. It will not look good on PC. To connect console or 4k player to play 4k UHD disc, ok it is not that bad idea to swithc even eshift on and use faked 4k, but for PC it is really pain, you will not like the image. Image it as if you buy some 1080p monitor and you put there any other resolution which is not native, you would not want to use and watch this smoother picture instead of sharp one.Hi
Opmerkingen
Regards
Atari
I have seen it also with my Epson TW7000. Could be a HDMI switching issue. Switching inputs and green screen . I think i also did a hot swap of HDMI and then only noticed it. I don't remember seeing it before then.Hi all, I just replaced my TW5900 for the TW7000, what a difference! But...I now encounter green screens while watching tv?!?! Not permanent but every few seconds I get a green screen,
I did not change anything but the beamer. Watching via a yamaha amplifier. Never had this problem with my T5900. Has someone an idea how to solve this??
After thinking about getting a new projector for the past few weeks, I've just ordered the TW7000 to replace my old Acer DLP projector (seen as it is reduced on the Epson store to £899). Should be arriving some time next week.
Not sure if its the same as my projector, but try Digital cinema or cinema mode, under colour mode.I have tw7000... I only get 8 bit color in information about signal... Do you get 10bit? I play br uhd
through samsung uhd m7500... i try few cables... they work with pc and tv uhd with 10bit...
