Epson EMP-TW10H, geometry problem.
Discussion in 'Projectors, Screens & Video Processors' started by ArsoN, May 20, 2005.
  1. ArsoN
    ArsoN
    Well, I finally took delivery of my Epson today, and WOW, what a picture. I have a few niggles though, my first rickety DIY screen is not high enough compared to it's width (about 3cm off), and I was just wondering if there's a way I could zoom the image out a little (projector is on minimum manual zoom) so it'll fit in the top and bottom bars?
    On the whole, it's an awesome PJ for my first buy, and I'm thoroughly hooked on HC now. Bring on the dedicated room!
  2. dave_h34
    dave_h34
    Feb 27, 2005
    169
    +11
    Did you make your DIY screen using a 16:9 ratio? I'm convinced my tw10h projects and image too 'tall' for its width i.e. not the correct ratio!
  3. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    Try to avoid max / min zoom, as you've found it leaves no room for adjustment if needed.
    Either make the screen bigger, or move the PJ closer to the screen.
    ...PJ :)
  4. dave_h34
    dave_h34
    Feb 27, 2005
    169
    +11
    Is it?! Bo^&$%ks, I've been using "normal" to watch widescreen, I didn't think it looked correct. Just to confirm then, I should have my 575 output set to "16:9 Widescreen" and the Epson set to "squeeze"? What a numpty I am!! Do you get any vertical banding btw?
    Cheers. :thumbsup:
  5. ArsoN
    ArsoN
    Just watched a movie on squeeze mode, much better. The small black bars at the top/bottom covered any overspill I had, made the film much more enjoyable to watch. Thanks for the tips (getting my manual back out now).
  6. dave_h34
    dave_h34
    Feb 27, 2005
    169
    +11
    I re-read the manual too, talk about clear as mud, to me it says:
    use 'normal' mode as this will project whatever the source is giving out
    but also says:
    use 'squeeze' to correctly project a 16:9 input!!!
    A bit of net trawling would suggest that squeeze is indeed the one you should be using, its the one that 'unlocks' the anamorphic screen info in dvds. Epson should really be capable of producing better manuals imo.
    Does look better now though!
