Epson EMP-TW10H Connection problems!
Discussion in 'Projectors, Screens & Video Processors' started by anflemin, Nov 4, 2004.
  1. anflemin
    anflemin
    I have just bought an Epson EMP-TW10H LCD projector which I would like to be able to use for both my DVD player (Pioneer NS-DV55 all-in-one Home Cinema) and digital cable TV (NTL with a Pace digi-box).
    The projector has a choice of S-VHS, RGB Component video and Composite video inputs and since the Pioneer system has S-VHS inputs and outputs I thought the easiest acceptable image quality option would be to stick with S-VHS. Playing DVDs is fine but the problem is with the cable TV image. I am routing the cable box via the Pioneer DVD through a SCART to S-VHS interconnect, my smart idea being that then I only need the one connection between the DVDs S-VHS output and the projector. However, when I send the cable TV signal to the projector it is black and white.
    I have checked settings on all 3 devices and I suspect that the problem might be down to the available signals from the digi-box - only RGB or composite are listed as options. Does this mean I can't send the cable signal through the DVD's S-VHS inputs/outputs and into the projector's S-VHS output. If so, I'm assuming I can get round this by using SCART to RGB direct from digi-box to projector, it's just that I was hoping to minimise the plugging and un-plugging, not to mention the cost of buying a second 5 metre video cable!
    Can anyone confirm that this is the problem and come up with an alternative solution?
    Cheers,
    Andy.
