Epson EMP-TW10H Aspect Ratio DVD
Discussion in 'Projectors, Screens & Video Processors' started by johnniekipper, Nov 23, 2004.
  1. johnniekipper
    johnniekipper
    Most of my DVDs play fine on my Epson. I usually use the zoom setting. Some DVDs (I Robot and Terminator 2) play with the image squashed a bit so everyone looks thinner than they should. What am I doing wrong ? is it something to do with anamorphic dvds or something ?
  2. maxiboy
    maxiboy
    You should set your DVD player to widescreen and the projector to "squeeze". You would only need to use the zoom if you wanted to get rid of the black bars on films wider than 16:9 ratio.
  3. johnniekipper
    johnniekipper
    Thanks maxiboy - I'll try that tonight.
