qwertz1525
I got my hands on an Epson EB-575Wi projector that has a smart/white-board feature. Using some special pens you can use the beamer as digital whiteboard. These function works stand-alone with a projector or in combination with Epsons "Interactive Tools" software installed onto a pc.
I have two problems with it: at the moment I get two lines drawn when I use "interactive tools" on an attached pc with one of the two digital pens. One line is from standalone feature the other from "interactive tools". So is there any way to disable the standalone feature?
The other problem is calibration. No matter if I use automatic or manual calibration (touching green dots with a digital pen) pens are getting out of sync on borders, especially at the bottom of the screen. At the bottom pens are about 10 centimeter off. Is there any way to improve accuracy?
Thanks for your help!
Mario
Mario
