I have screws for a universal mount but they do not fit my new EH-TW 9300W they did fit my JVC x30, I just need to know what the exact mm size of the screws are that fit the EH-TW 9300W the screws i will get are like the attached image are these ok (they are about an inch long)
I had same problem with my Sony VPL-HW55 projector, screws that came with my projector mounts did not fit the mounting holes on my projector, in the end I just bought 3 different lengths of M4 screws off ebay until I found the correct fit.
I have two different projector mounts, both take different length M4 screws for the mounting holes on the projector, one mount took M4 16mm, the other mount took M4 12mm (both with a 8mm head) your epson will probably be a different size screw, although 1 inch (25mm) seems to big to me.
I found allen key type screws are the best for the mounting holes (rather than the pozi type) you can achieve a much tighter fit.
