Epson 2040/TW5210/TW5300 fan noise query
Discussion in 'Projectors, Screens & Video Processors' started by thirdwave, Apr 7, 2016.
  1. thirdwave
    thirdwave
    Mar 11, 2016
    15
    United Kingdom
    I own the Epson TW5210 for a month now and was happy with it until I decided to ceiling mount it yesterday-I've since noticed that the fan is significantly louder even in Eco mode once I flip the image orientation using the 'front-ceiling' setting-it so bad I'd initially thought the projector was faulty but this does not seem to be the case since the problem resolves when I restore the original image orientation. I have not changed any other settings,the high altitude feature is off etc..
    Anyone else encountered the issue and if so is there a fix for it?
    Many thanks
