ched
Established Member
I have almost made my mind up to buy the TW10H, in fact its about the only pj I can afford. But it will be so much better than my old Marantz pj.
Anyway back to the point. I have Sky+ well will have on Saturday and a cheap LG DVD/Video /DD combi unit. Its only temp as my normal Sony, Paradigm, and Mordaunt Short stuff has to be packed away till I move. I understand that the TW10H has a number of connections available and the best one to use is the component. Well when I look in to it it seems like I also need a sync cable.
Bottom line is how do I get component out of the sky+ and to the pj? Do I just need a scart to component convertor such as lektropacks SARGB 4X phono RGB + composite Sync and 4 long phono to phono leads?
Is this correct? Any help is most welcome. Thanks.
