Eproformance DVD-R Disks
Discussion in 'Blu-ray & DVD Players & Recorders' started by gram99, Apr 18, 2003.
  1. gram99
    gram99
    Anywhere online where I can get these, they are the most reliable in my Panny E30.
  2. ferris57
    ferris57
    Jan 18, 2003
    874
    Only place I've seen them is svp. Haven't had them in a while but they have constantly changing stock depending on whats available. Might want to keep an eye on them, I imagine they will be back in stock fairly soon. Not much help at the moment though! There is quite a bit of new media out at the moment though, might be worthwhile trying a new sample pack and see if any of it is any good.
  3. gram99
    gram99
    ok cheers m8
  4. Fuel Crusher
    Fuel Crusher
    Nov 24, 2002
    104
    16
    UK
    E-proformance also worked great for me on my E-30, better in fact than the pack of traxdata that I've had to replace them with.
    The E-proformance were made by Prodisc and I'd imagine they've stopped making them as they were only 1X. It may be worth trying some other prodisc made discs although on the whole this make of disc were not rated very good, E-proformance seemed to be the exception.
    Paul.
  5. gram99
    gram99
    Any suggestions then for a replacement?
  6. Fuel Crusher
    Fuel Crusher
    Nov 24, 2002
    104
    16
    UK
    Afraid it's still very 'suck it and see' with dvd-r. What works well on one e30 might be crap on another. Generally the Ritek discs are well regarded and also the new samsung dics are supposed to be excellent but hard to source.
  7. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,554
    7
    167
    Birmingham, UK
    +10,383
    gram99 - the email address you have in your forums profile is invalid - please update it or I will have to delete your registration.
  8. gram99
    gram99
    Done, apologies.
  9. stevieg
    stevieg
    Dec 12, 2002
    3
  10. gram99
    gram99
    nice one cheers m8
  11. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,885
    3
    48
    +79
    You could try,like me,Panasonic direct off their web site via their e-shop for DVD-RAM/-R,as they're very cheap and gotta be guaranteed to work.
    :clap:
  12. DaveP
    DaveP
    You must have more money than me if you consider £2.64 PER Disk very cheap!
    DaveP
