EPilot - Do I need original remotes to teach it?
Discussion in 'Home Cinema Control & Remote Controls' started by Jamp, Jan 18, 2004.
  1. Jamp
    Jamp
    Aug 8, 2003
    76
    Sheffield/N Wales/Isle of Man
    I'm thinking of the EPilot for £30 from Maplin, the info says it's a learning remote.
    I have a Sherwood AV Amp that I bought 'open box' and came without the remote. Will the EPilot be able to operate the Amp without being taught by the original?
    Cheers,
    Ben
  2. mxs
    mxs
    Nov 28, 2003
    236
    Lowestoft
    +9
    The e.pilot is a learning remote only, there are no codes built into this unit, and I believe you lose all the settings when changing the batteries too!
  3. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    Its a learning remote and you will need the other controller.
    You can change the batteries without losing settings though - you get something like 1.5 minutes.
  4. Jamp
    Jamp
    Aug 8, 2003
    76
    Many thanks for the replies. Any suggestions of what I should do then? Don't really want to spend much more than that. Reckon Richer Sounds (where I got the amp) would let me borrow a remote to teach an E-Pilot with?! :p More likely if I were buying it from them I suppose.
    Cheers,
    Ben
  5. spdp5tc
    spdp5tc
    You will have to hurry if you want an E-Pilot. Discontinued on website (cancelled my order). Phoned them up and they gave me stock numbers at shops in my area. Phoned up shop to reserve after previously going to another and finding they had ran out.
    Great remote for the price and easy to set up / learn from other remotes.
  6. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,796
    41
    Kent
    +18
    Do you have a pal with a Pronto? If so pehaps they could D/L a CCF file for your amp from remote central and you could teach the epilot from the Pronto.
    Just a thought.
    Mark.
  7. Jamp
    Jamp
    Aug 8, 2003
    76
    Thanks for the replys folks.
    Good plan with the Pronto idea, but I don't know of anyone with one unfortunately.
    What about a Kameleon? £50 in Argos, I suppose I could stretch.... Would one of those do the trick without needing the original?
