EPG got wiped again....
Discussion in 'Microsoft Windows' started by Rambles, Aug 1, 2005.
  1. Rambles
    Rambles
    Jul 14, 2004
    8,495
    UK
    +1,357
    Anyone else has this?
    Had to remap tv listings to each channel, and re-set up all my series recordings :mad:
    No new services / channels available on a re-scan so I didn't even get anything new out of it, is this a 'feature' of MCE?
  2. hebawom
    hebawom
    Apr 16, 2004
    187
    19
    Matlock
  3. Rambles
    Rambles
    Jul 14, 2004
    8,495
    UK
    +1,357
    Oooh, how exciting an update :clap:
    Wonder if that will bring more problems than fixes....?
    Not that I'm cynical about Microsofts programming skills of course :rolleyes:
  4. Slinkoff
    Slinkoff
    Oct 14, 2004
    699
    28
    +24
    Surely these mappings must be stored somewhere that can be backed up and replaced if needed? I'm not currently using MCE for recording TV so I can't check.
    Best way to find out is to make some changes to your mappings and then search your whole machine for files that have been edited on the current day and then sort the results by date and look at the most recent. There might just be some config file somewhere or if it's ntuser.dat then it will be registry changes.
  5. Dunkwho
    Dunkwho
    Sep 3, 2001
    531
    28
    Dunstable
    +24
    mine went yesterday too ... was fine on sunday evening, don't think i checked yesterday morning, had to re-add the guide to the channels yesterday pm tho (must remember to go back and fill in the whole lot - only did 1-5 so that my scheduled recordings would work ! :D)
  6. Rambles
    Rambles
    Jul 14, 2004
    8,495
    UK
    +1,357
    Slinkoff - great suggestion, I had a look but nothing obvious leapt out at me, it seems to be stored in the Documents and Settings folders according to the registry but there are lots of files in there with extensions I have never heard of, so I left it alone.
    Dunkwho - not on the Crystal Palace transmitter are you?
  7. Dunkwho
    Dunkwho
    Sep 3, 2001
    531
    28
    Dunstable
    +24
    no - sandy heath (bedford) transmitter ...
