EP35 firmware rollback procedure?
Discussion in 'Blu-ray & DVD Players & Recorders' started by -Hitman-, Jun 5, 2008.
  1. -Hitman-
    -Hitman-
    Mar 21, 2005
    4,815
    Sector7
    +1,112
    I'm trying to resolve a problem i have with my EP35 and ask if anyone knows the rollback procedure for downgrading the firmware from 2.0 to 1.3?
    I have aquired the US A35 1.3 firmware but i'm sure it needs patching or something as i have already burned it to a disk but the player states that it has been upgraded and quits without loadcing the firmware and downgrading to 1.3.
    Has anyone done this sucessfully?
    TIA.
  2. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +8,752
    Hi -Hitman-. :)
    The 1.3 rollback should work just fine :confused: did you get the link of me?
    All the best.
  3. -Hitman-
    -Hitman-
    Mar 21, 2005
    4,815
    Sector7
    +1,112
    No, i found a copy on my laptop, can't remember where i downloaded it from:confused: but it looks like it's probably an untouched original
    Whats your link and i'll download your working copy?
    TIA.
  4. MarkusThatch
    MarkusThatch
    Dec 20, 2004
    9,686
    2
    +1,763
    Out of interest, what's the problem with your ep35 - why do you need to roll it back to 1.3?
  5. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +8,752
    I'll send a PM. :smashin:
  6. -Hitman-
    -Hitman-
    Mar 21, 2005
    4,815
    Sector7
    +1,112
    Thanks Kingfats:)
    This time it worked and have got back to 1.3:thumbsup:
    Did it fix my problem? NO:(
    I'll see what Toshiba say.
    My EP35 won't output 576i for PAL and 1080P24 for HD-DVD, when using the resolution setting 480i/576i, which is suppose to disable upscaling, instead the player insists on putting out 480i 60hz for HD-dvd's:(
  7. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +8,752
    I remember you saying about it :( it didn't fix it then........bad luck mate.
    Keep us posted with what Toshiba say.
  8. -Hitman-
    -Hitman-
    Mar 21, 2005
    4,815
    Sector7
    +1,112
    Thanks Kingfats will do!:)
    I've received an email saying that the problem has been passed on to technical, waiting for them now!
    1 good thing being at v1.3 is it now always sends out 1080P24!
