EP30/Optoma h79 problem
paulmcg
Established Member
Hi there,
I received my EP30 a couple of days ago and am pleased with it so far, however...
When I connect to my Panny plasma, all works perfectly all the way to 1080p.
But, if I have the machine connected to my PJ (Optoma H79) via HDMI/DVI-I lead and I get no picture at all. I have tried multiple max resolutions (from 480 to 1080), I have replaced cables, and have used the Optoma HDMI/DVI-I adapter.
The projecter supports HDCP. I think I have seen a purple flash a couple of times when I have first switched on (if I have the PJ on first).
Sky HD works as 720p/1080i using the same cables.
If I connect the Ep30 via component, I get 1080i no problem.
Any ideas?
Thanks,
Paul
jon1
Hi there,
Any ideas?
Thanks,
Paul
Hi paul ..is the adapter connect all the time?
jon
paulmcg
Established Member
Hi Jon.
Only when I use an HDMI-HDMI cable. I have used this combo once.
I normally use an HDMi to DVI-I cable. That is the standard cable i used on both my previous DVD player (Denon 1920) and sky HD.
Paul
jon1
Hi Jon.
Paul
Paul ..i have a profigold HDMI to DVI-I cable had no problems ..had a tosh a1 now the xe1 ..and a ps3 going through my h78..so do you think it may be the adapter?btw the cable is 10m long
jon
paulmcg
Established Member
Hi Jon,
I don't think it can be the adapter.
I have used the adapter with the HDMI-HDMI cables and without the adapter for the HDMI-DVI cable.
Both are decent cables and both are 10-15mtr long. Never had a problem with either cable with any other application (Sky HD, Denon DVD etc).
Paul
⭐ Philips OLED908 TV & Musical Fidelity A1 amp reviews + a look at two home cinema speaker packages
Back
