Hi all,
I recently bought an EP30 from ebay and have noticed that if I switch it off at the plug, the next time it's on it asks me to set the clock again?
My E1 doesn't do this...anyone know what might cause it? The firmware is also the original one too.
Cheers,
Paul.
This problem is apparent with all EP30's regardless of what firmware you may have. I have the latest firmware and I still lose the clock should I remove the plug. Hope this helps.
Why do you need a clock in a hd dvd player?
My EP35 does this as well and I find it quite irritating. The easiest solution is to ignore it and press open while it is asking for the time.
While playing with the "web enabled" feature, I noticed that if the player is connected to the internet and NTP server is specified then it does not ask for the time when it is switched. Whether it is worth going to this much trouble to shut it up is a difficult question. I have not yet checked whether specifying NTP server but not connected it also shuts it up. I will try tomorrow, enough for tonight.
I used to have this kind of behaviour with my EP30 but not anymore. I am not sure why though. I didn't use my player for a while, upgraded it with the latest firmware and the region hack, conected it to a different tv and after that I never got the screen asking to enter the time and date again. And I do completely disconnect the power every day. Maybe one of the steps I mentioned did it?
