Eos 300D and studio lighting
Discussion in 'Photography Forums' started by Ricardfred, Jun 22, 2004.
  1. Ricardfred
    Ricardfred
    Feb 5, 2004
    83
    I would like to buy a studio lighting kit, such as the Interfit lighting kit at Jessops, to use with my Canon 300D/Digital Rebel. However from trawling the internet I came across some posts mentioning these kits having too high a voltage and could damage the 300D. I must admit that I am confused and would love to hear if anyone is using the 300D with studio lighting. Would the 550ex speedlight be my only option? I will be photographing mainly art paintings indoors and have to avoid direct flash and lighting due to glare on paintings. Any tips? :confused:
  2. Juliesinar
    Juliesinar
    Oct 28, 2003
    899
    +58
    I have a 10D but have not tried using studio lighting yet, but I do remember reading about a little device called a WEIN Safe-Sych which is supposed to reduce flash voltages to 6V.
    They are available from Jacobs web site for £45.79, it might be worth doing a little bit of research to see if it would be suitable for your needs.
    http://www.jacobsdigital.co.uk/products.php?productId=8730
    Sorry I can't offer any more advice but I have never photographed paintings, I would have thought bouncing a 550ex would offer decent illumination, but of coarse you would have to be careful of the colour of the surface you were bouncing of to prevent colour casts. I often use a lumiquest pocket bouncer which is great for diffusing flash light. Jessops sell them for £18.99
    http://www.lumiquest.com/lq871.htm
    Julie
  3. Ricardfred
    Ricardfred
    Feb 5, 2004
    83
    Julie
    many thanks for those links. The LumiQuest Big Bounce is something I will investigate along with the flash. It certainly would be lot easier to carry around.
