I have just got the free energyfit monitor from eon. No problems installing and everything works in general terms, but I have a software problem I think.
The screen display seems odd. The chart showing energy use is partially obscured by the red buttons saying 'home' 'download' etc. The buttons intrude into the graph area so I can't see the axis along the bottom. Also some detail options on the right are obscured. It seems as though the frame with the graph in is either too small or set as background so the foreground info sits on top and partially obscures the data.
Is this a known issue? Can anyone suggest a fix? Many thanks
Windows 7 64bit
