Entry level advice
Discussion in 'AV Receivers & Amplifiers' started by lynx, Apr 9, 2002.
  1. lynx
    lynx
    Jan 20, 2002
    4,652
    It always rains.
    +302
    A chap at work has been asking for ideas to get into hc.He already has a dvd player so is looking for some amplification coupled with speakers/sub.Which of the packages are the ones he should be looking at and which are to be avoided?He will no doubt be looking at the all in one type packages but all suggestions will be passed on.No budget as such was mentioned but i would guess at around the £600 mark.Thanks.
  2. Guest
    I recently purchased a paramount hcs5300 amp and speaker package, its only available through debenhams, comes with five speakers plus sub, dolby digital and dts decoding includes an AM and FM radio. As a starter amp it sounds superb, the only thing i would suggest is upgrading the cable that comes supplied it makes all the difference.
  3. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,740
    7
    2
    167
    Birmingham, UK
    +10,630
    Well the best advice I can give, Lynx is for your friend to read HCC, What Video & Total DVD.
  4. lynx
    lynx
    Jan 20, 2002
    4,652
    It always rains.
    +302
    I wouldn't argue with that.I would certainly encourage him to do his own research and to audition with his ears but if I could point him in the right direction with some personal recomendations from you guys then that would be good.
  5. dodocream
    dodocream
    I was in this boat a while ago, but needed something pretty discreet so in the end settled on a Marantz SR4200 (£260) and Mission FS2-AV speakers (£360). Haven't actually got them yet (come on avland.co.uk!!) but am reasonably happy with my choice.
    However for your friend I wouldn't really recommend the missions unless space is an issue - there are better speakers for the price - check out some of the entry level stuff on the Mission, Tannoy and Eltax ranges. This should save him enough to upgrade to the SR5200 (£350) giving him more oomph plus 6.1 support. Yamaha and Sony also seems to have good amps in this price range. HTH, but the best way of course is to send him off to a hifi shop with a list of possibles and let him audition for himself.
    Regards,
    DDC
  6. lynx
    lynx
    Jan 20, 2002
    4,652
    It always rains.
    +302
    Thnks for the comments guys.It might be better to let this one die.He has been spotted looking at something in Powerhouse for £200 :rolleyes: .
