Hi folks, first post
We're considering buying a new TV to replace our current 8-yr old JVC 28" CRT. We've got a bit of catching up to do, can't believe the amount of variety and a lot of it just goes waaaay over my head...
Our budget is £400-500. We've don't want to spend more as we don't watch that much TV or DVDs. I think I've limited it down to plasma based on our intended uses but please correct me if I'm wrong:
- freeview SD (we don't have a freeview HD box, possibly something for future)
- mainly sport we watch on TV plus occasional programmes
- DVDs mainly
- no gaming, doesn't interest us
- use in our main room, lighting usually dim so plasma seems well suited
- no need for good sound as it'll be connected to our external audio set up (Denon/JM Labs)
I'm considering something along the lines of an LG 42PQ2000 @ £350 but have slight reservations about it not being 1080p.
Am I right to be worried?
Would I notice the difference between this and a budget 42" 1080p TV?
The reason I'm worried (again I could be wrong in my thinking) is that we'll probably end up buying more titles on blu-ray as my wife's laptop has a built-in blu-ray drive. My mate reckons we'd notice the difference between HD-ready and 1080p on a 42" screen, correct?
There's a bit of price jump up to a 1080p 42" plasma and TBH it's beyond what we want to spend, but if it was going to make a massive difference to picture quality then we're probably hang on and not buy now...
Sorry for all the Q's! Happy to listen to any advice about the suitability of the above TV, or any other suggestions. But please, if you make suggestions please remember our tight budget and also please clarify why you'd suggest something else over that LG model above. Not asking much, am I
Many thanks
Ally
- DVDs mainly
Many thanks
Ally
