Entering Postcode destinations TT1
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by MStarkey, Jan 4, 2007.
  1. MStarkey
    MStarkey
    Jan 2, 2005
    268
    Nottingham
    +37
    Is it me or does the Postcode function behave strangely on the TomTom one?
    For example if I know the postcode of my destination I seem to be able to enter the first 3 digits eg. 'WF9' from the full postcode of WF9 2XR but then all I can do is select a street rather than entering '2XR' or 'space 2XR'. I realise that there is no way to put a space in so does that invalidate the use of these postcodes?
  2. Sonic67
    Sonic67
    Sep 14, 2006
    45,573
    11
    167
    Home
    +24,265
    Are you entering on the enter address bit or on the second screen where you can enter a postcode? I have a Tomtom 300. I used to enter on the street address bit until I realised you can enter the postcode on a different screen.
  3. sinizterguy
    sinizterguy
    May 19, 2005
    1,007
    48
    +47
    Seems to work fine for me.
    You dont need a space at all ... Just type in for example EC1M6BQ instead of EC1M 6BQ and it works.
  4. MStarkey
    MStarkey
    Jan 2, 2005
    268
    Nottingham
    +37
    I select 'Navigate to' then 'Address' then 'Postcode'.
  5. MStarkey
    MStarkey
    Jan 2, 2005
    268
    Nottingham
    +37
    As you say it works fine if the postcode is a full 7 digits but the one above is only 6 !
  6. sinizterguy
    sinizterguy
    May 19, 2005
    1,007
    48
    +47
    The 6 digit ones work fine as well - just enter without the space. It was just an example.
  7. UrbanT
    UrbanT
    Jan 6, 2002
    13,312
    Aldershot, Hants
    +3,038
    I've just tried this on my 'One', which I've only just bought, and hasn't even seen the car yet!
    Anyway, put in the post code from the first post, and it seems to work fine, giving Stadium Way, South Elmsall.
    As for the 6 digits, you should notice that as you put in Post Codes, the TT automatically adjusts betwen 6 and 7 digits as you put the information in. Perhaps you have a dodgy unit?
  8. MStarkey
    MStarkey
    Jan 2, 2005
    268
    Nottingham
    +37
    Just tried this again - WF9 gives me 'WF9 (Pontefract)' adding a '2' does nothing adding a 'X' does nothing etc - is that correct ?
