Enhancing Mono
Discussion in 'AV Receivers & Amplifiers' started by Stepe, Oct 14, 2004.
  1. Stepe
    Stepe
    Hello All,
    I have a Yamaha DSP-A595 Dolby Digital amp which, although very good with 5.1 soundtracks only has Mono Movie DSP for older mono movies. I don't like it much, as it causes an unnatural reverberating sound to soundtracks. I was wondering, is there some other way of "enhancing" mono dvd soundtracks?
    Thanks very much for any help, it's greatly appreciated.
    :thumbsup:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    does it have pro-logic or Prologic 2? or even Circle surround.
  3. Stepe
    Stepe
    Hi HornyDragon,
    It has Dolby Pro Logic. No DPLII. No Circle Surround.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    have you tried using PL for these discs?
  5. Stepe
    Stepe
    Many times. On 1.0 Mono the sound comes out of centre channel.
    On 2.0 Mono the sound comes out of LF and RF. That's all.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    hmmm PL is very centre biased.... are you using digital connection for DVD to amp? How about using analogue connections from DVD to amp?
  7. Stepe
    Stepe
    I use coaxial lead from Dvd to Amp. What difference will useing analogue connections between the two make? How will that enhance mono soundtracks?
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    DVD player may process it upto stereo (dual mono) and allow the amp to process more effectively... worth a try if you have a cheapie stereo pair knocking around..... most people do!
  9. Stepe
    Stepe
    Dual Mono is not Stereo.
    But I'll try that anyway. Anything is better than mono coming from a centre channel. Thanks for your help. :)
  10. Stepe
    Stepe
    Okay tried that, but not much better.
    Anybody any other ideas? :lease:
  11. ktng
    ktng
    May 9, 2004
    174
    16
    UK
    Without some of the newer processing I think you are stuck with listening to mono movies in stereo (ie no DSP) if you don't like the Mono Movie DSP.
  12. Wasabi
    Wasabi
    May 16, 2002
    1,188
    48
    SBC (Swedish Born Chinese)/lived in UK since 96, C
    +32
    I have an idea, get a receiver with Circle Surround II, the absolute best dsp for mono channel. Really good surround sound on mono channel (and on stereo sources too).
    I think Marantz still has CSII, even on the new x500 series, but otherwise CSII seems to lose out in the battle of dsp's. Kenwood has stopped including CSII.
    Wasabi
  13. Stepe
    Stepe
    Thanks guys for your help.
    I'll look into Circle Surround II Wasabi , thanks.
  14. Stepe
    Stepe
    Okay, Can't afford a new amp with Circle Surround.
    I have heard there is a way to rip a dvd audio and Edit/save 6 mono files in audacity. Then re-join these with the ripped video. How?
    :lease:
  15. ktng
    ktng
    May 9, 2004
    174
    16
    UK
    Not sure how you would do it with that software, but you would need some dvd authoring software that supported dd/dts 5.1 soundtrack and I think you would find that you would loose the original menu and unless you have a dual layer burner you may have to either split the movie over 2 discs or compress the video to fit onto a single disc.
    I suggest you have a look on doom9 and videohelp for lots of information on this; it also has guides for a lot of software packages.
  16. Stepe
    Stepe
    Many thanks for your help. At least you have pointed me in the right direction. I'll have a look at both Doom9 and VideoHelp for further help. :clap:
