Engraved iPod and battery replacement questions...
Discussion in 'Headphones, Earphones & Portable Music' started by danwalton, Mar 12, 2005.
Tags:
  1. danwalton
    danwalton
    Feb 15, 2005
    2,304
    +118
    Hey, just a couple of issues that i'm concerned about. Firstly, I read somewhere that Apple will not accept an engraved iPod back for repair/battery replacement. I find this hard to believe, but is there any truth in this? Anyone had a battery replaced, and if so was it as good as new? Secondly, if you do send your iPod in to have a battery replaced, is the one that is sent back to you exactly the same one you sent (plus a new battery), or a refurbished unit? Finally, realistically when can we expect to see the next generation of iPod arrive? Thanks for any help! Dan
