Engineers menu sky digibox...
Discussion in 'Sky Digital TV Forum' started by jonnyv, May 16, 2002.
  1. jonnyv
    jonnyv
    Mar 31, 2002
    2,320
    48
    +59
    Ive found out how to get the engineers menu on my sky digibox.
    i bought a sony slimline box to replace my panasonic..the panasonic was installed by the sky engineer but the sony was just plugged in and switched on by me.
    Do i need to alter anything in the engineers menu or are all lnb settings etc. the same ?
    cheers
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    As long as your smartcard is working with your new box then you don't have to change a thing.
    Unless for some bizarre reason you use the RF1 outlet connected to a TV or maybe the RF2 if you use the TVlink system and then only if you changed the default settings on the Pana.
