Engine flooding problem
Discussion in 'Motoring' started by jendo, Feb 11, 2009.
  1. jendo
    jendo
    Feb 9, 2006
    656
    46
    london
    +147
    Hi, I have a problem with my Nissan qx (1997) Its struggling to start from cold, the symptoms are what you would expect form a flooded engine. Could it be a sensor problem? Will it have to go on a diagnostic? Not sure what to do, considering any repair will probably cost more than the cars worth and its starting to become a money pit. Thinking about just scrapping the old girl but cant afford a replacement at the moment.
    thanks in advance for your opinions.
  2. Ayub
    Ayub
    Oct 15, 2003
    6,647
    Bradford
    +612
    Have you cleaned your plugs
    ( spark plugs) :p
  3. jendo
    jendo
    Feb 9, 2006
    656
    46
    london
    +147
    no mate, they are platinum. Does that make a differance?
  4. Ayub
    Ayub
    Oct 15, 2003
    6,647
    Bradford
    +612
    Petrol engines are not my cup of tea.
    I suggest you remove the plugs and check them. See if your vehicle is firing on all its cylinders.
