Energy Veritas 2.2i piano black finish peeling off
Discussion in 'Home Cinema Speakers' started by naturelover, Aug 15, 2013.
  1. naturelover
    naturelover
    Aug 12, 2013
    10
    Hi!
    I own a pair of Energy Veritas 2.2i speakers. I have noticed that the black gloss finish has come unstuck on one of the speakers.
    How do I stick it on again? Can I use normal glue?
  2. Don Dadda
    Don Dadda
    Sep 20, 2007
    5,655
    London
    +728
    Not sure whereabouts on the speaker we are looking at - Is it the bottom corner of the speaker? Pretty hard to spot the peel.
    I gather that the black gloss is sprayed onto veneer which covers the speaker. If so I would probably use some carpenters glue and by the looks of it, only a tiny amount is needed. I would also use some masking tape to cover the surrounding areas for any over spill.
  3. naturelover
    naturelover
    Aug 12, 2013
    10
    Thanks Don,
    Yes, it is the bottom corner. I am attaching another photo. The speaker is lying on its side with the bottom face facing the camera. Hope this pic makes it more clear.
  4. Don Dadda
    Don Dadda
    Sep 20, 2007
    5,655
    London
    +728
    It sure does and how wrong was i. And i thought that the yellow was some kind of border when in fact its the mdf of the cabinet. I need to wear my glasses more often.
    I can understand a corner or edging peeling but that is peeling off like a shoe box cover. Does it come right off?
    Seems like it wasn't glued properly when made. Something that probably wouldn't be pick up during quality testing though i would of thought they'd have a test for that kind of thing.
    How old are they?
    If there is any warranty left, definitely take it back. Or if not, you could try contacting the manufacturer and send some pics. Some are kind enough to sort that for free even if no warranty as that is a product defect that really should not happen.
    In falling that, carpenter glue stands but you may want to get someone who knows what they are doing for a clean, bubble free finish
  5. naturelover
    naturelover
    Aug 12, 2013
    10
    Thanks again.
    The speakers are fairly old. No, the coating does not come off fully.
    I have now written to Energy. Let's see what they come back with and I'll take it from there.
