I have mangaged to track down some Energy Take 5.1 speakers. I have decided not to purchase the 8.2 subwoofer because i believe that my BKXLS200 is better.
I will be replacing my current Small Satellite speaker (yamaha NSP220) with the Energy Satellites
The Polk site recommends the following config:
That the Fronts are set to Large,
That 'NO' subwoofer is specified,
The Sub is connect to the Amp via the Hi Level inputs
and that the Subwoofers Crossover is used instead of the Amps
See Below
http://www.polkaudio.com/home/faqad/advice.php
article=bassmanage
However the common point of view is:
That the Fronts should be set to Small,
That a Subwoofer is specified.
The Sub should be connected with a Phono lead,
and the amp should control the crossover
What do you all think?
Have any of you used the Energy Take 5.1 package with an alternative subwoofer?
See Below
article=bassmanage
